Att göra om en rhino MkII till rhino MkI
Från Erik Holz
This is the template as promised. It includes all the components necessary
to convert your Mk. II's into Mk. I's. The template has the instructions
for where to cut and where to score. Scoring is not necessary, it just aids
in even and proper placement of components.
Additionally, the plasticard pieces that go above the tracks are
intentionally slightly too wide. This is to allow you to file down the
pieces to ensure a smooth edge with no gaps and to make sure you have a nice
sharp corner. You may have to do additional filing along the curves of the
plates that contact the exhaust as its not easy to get a perfect curve.
Lets be honest, no one is going to build their rhinos to the exact same
size. Finally, the track pieces that go above the front and rear track
openings are intentionally long. This is to also allow you to file them
smooth to the plastic kit making a flush edge. Rivet placement has been
altered accordingly to accomodate any filing youd need to do. For the 4
tabs that are attached to the rhino door you will want to use a thicker
plasticard of your choice. You may also want to use a thicker plasticard
for the "foot rest" that goes below the side hatches, just because it may be
more stable for gaming purposes.
When printing make sure you have any sort of scaling turned off. Just pring
the file with no scaling or centering. Some printers auto scale which will
screw up the template sizes.
A final reccomendation is to use my rivet placements to drill tiny holes
with your hobby knife while the template is STILL ON THE PLASTICARD, this is
a life saver when trying to place rivets later on! TRUST ME!
I'm not sure the A4 is to the proper scale, if not, please let me know and I
will fix it.
Anyways thanks for the support, and here it is.
Now go forth and make legions of old school rhino's! :)
mk1_final_A4.pdf.pdf
(502.92 KiB) Nerladdad 116 gånger
mk1_final.pdf
(508.8 KiB) Nerladdad 114 gånger
