Dark Angels
Moderator: Kompmallsansvariga
Jimmy Johansson
Re: Dark Angels
Inlägg av Jimmy Johansson »
Land Raiders och Dreads är inte uppdaterade vad jag såg iallafall.
GLinus
Re: Dark Angels
Inlägg av GLinus »
Här är ett litet morfininspirerat förslag på ny komp för DA:
Dark Angels
Starts at 115 Points
Dark Angel Army definitions:
Green Wing: An army that contains no Deathwing- or Ravenwing units.
(Pure) Deathwing: An army that is led by Belial and only contains Characters in Terminator Armor, Terminators, Dreadnoughts and Land Raiders
(Pure) Ravenwing: An army that is led by Sammael and only contains Characters on bikes, Ravenwing Attack Squadrons, Ravenwing Support Squadrons and Landspeeder Tempests
Double-Wing: An army led by Belial and/or Sammael and only contain Death- and Ravenwing units.
Mixed-Wing An army that is a mixture of Greenwing and units from DW/RW
HQ
Company Master
-1 Pair of Lightning Claws
-2 Power Fist/ Thunder Hammer
-2 Jump Pack
Command Squad
-1 each Power Weapon
-3 each Power Fist
-1 each Plasma gun/Meltagun/Flamer after the first
Interrogator-Chaplain
-1 each Interrogator-Chaplain
-2 Power Fist
-3 Bike/Jump Pack/if there is a Land Raider in the army
Chaplain
Librarian
-10 Azrael
-5 Ezekiel
Belial
-2 unless in pure DW-army
-2 Pair of Lightning Claws
-5 Thunder Hammer & Storm Shield
Sammael
-10 on Jetbike
-7 on Jetbike in pure RW-army
-10 in Landspeeder
Belial+Sammael
- 5 (extra)
Elite
Techmarine
+2 each Techmarine
(25 poäng dyrare än LBMs motsvarighet och har förvisso 1W mer men har i övrigt färre specialregler och utrustningsmöjligheter
DW Terminators
-5 each of units 1-3 of Terminators
-3 each of units 4-6 of Terminators
-2 each of units 7-9 of Terminators
-2 first unit taken as Troop, unless in a Pure DW-army
-2 first Storm Shield in each unit
-1 each successive Storm Shield in unit
-2 Cyclone Missile Launcher
-1 DW Company Standard
-2 Apothecary
Dreadnought
-2 each Dreadnought
-1 first Dreadnought Close Combat Weapon
-3 Drop Pod
Company Veteran Squad
-2 Lascannon
-1 other Heavy Weapon
-1 each combi-weapon/Plasma gun/Meltagun/Flamer after the first
-1 each Storm Shield
-1 each Pair of Lightning Claws
-3 each Power Fist/Thunder Hammer
-3 Drop Pod
Scout Squad
+1 9th Shotgun
-2 Power Fist
-1 Power Weapon
Troop
Tactical Squad
-1 each Tactical Squad
-2 Lascannon
-1 Power Weapon
-3 Power Fist
-3 Drop Pod
Fast Attack
RW Support Squadron
-1 each Landspeeder
-1 each Multi-Melta
-3 each Typhoon Missile Launcher
RW Attack Squadron
-3 each unit taken as Troop in a mixed-wing-army
-2 each unit taken as Troop in a pure RW-army
-1 first unit taken if army contains Terminators
-3 second unit taken if army contains Terminators
-1 each Plasma gun
-2 each Meltagun
-1 Attack Bike
-1 Landspeeder
-1 Power Weapon
-3 Power Fist
-1 RW Company Standard
-2 Apothecary
(Är förvisso Scout och Fearless samt har Teleport Homers, men en squad på 6 man kostar 55 poäng mer än LBMs motsvarighet)
Assault Marines
-1 Power Weapon
-3 Power Fist
(10 man kostar 45 poäng mer än LBMs motsvarighet)
Heavy Support
Devastator Squad
-1 each heavy weapon
-2 Power Fist
-1 Drop Pod
Whirlwind
-5 each Whirlwind
Predator
-4 each Predator
-1 Sponsons
-1 Lascannon Turret
Vindicator
-5 first Vindicator
-8 each successive Vindicator
Land Raider (all variants)
-15 first Land Raider
-20 each successive Land Raider
+6 each Prometheus
+4 each Redeemer
+2 each Crusader
+1 if transport capacity does not exceed 10 models
-2 each Multi-Melta
Transports
Rhino
-3 each Rhino
Razorback
-3 each Razorback
-2 each Twin-Linked Multi-Melta
Vehicles (each unit of vehicles counts as one vehicle, Land Raiders counts as two, Drop Pods do not count)
-1 each for vehicle 4 & 5
-2 each for vehicle 6 & 7
-3 each successive vehicle.
EDIT: Lade, på Zurkens inrådan, till Dark Angel Army Definitions i början av förslaget för att klargöra de olika typerna.
Fluff är tufft!!
Re: Dark Angels
Du måste definiera "pure DW army", "pure Ravenwing army" och "mixed wing army". Jag tvekar på att alla vet vad det är.
Ser väl bra ut annars tycker jag.
GLinus
Re: Dark Angels
Inlägg av GLinus »
Zurken skrev:Du måste definiera "pure DW army", "pure Ravenwing army" och "mixed wing army". Jag tvekar på att alla vet vad det är.
Tack för förslaget!
Jag har lagt till definitioner i början av kompförslaget.
Fluff är tufft!!
Jocke Rapp
Re: Dark Angels
Inlägg av Jocke Rapp »
Jag tycker det är intressanta förslag. Men vi kommer inte att ta någon hänsyn till fluffaspekter som "pure deathwing" och liknande. Sammael blir inte mindre bra bara för att hela armén består av bikes.
jeppeapan
Re: Dark Angels
Inlägg av jeppeapan »
Varför ska lr multi-meltan ge -2?:)
GLinus
Re: Dark Angels
Inlägg av GLinus »
Jocke Rapp skrev:Jag tycker det är intressanta förslag. Men vi kommer inte att ta någon hänsyn till fluffaspekter som "pure deathwing" och liknande. Sammael blir inte mindre bra bara för att hela armén består av bikes.
Mina förslag har faktiskt inte med "fluff att göra, tro det eller ej.
Listan blir sämre eftersom Sammael inte "kan" backas upp av saker som predators etc om den är renodlad RW.
Ni tar ju hänsyn till synergier i andra sammanhang så jag förutsatte att det kunde vara en vettig idé att göra det där också eftersom det klart påverkar hur bra listan blir. Om vissa val kan få högre avdrag om specifika andra enheter finns med i listan, så borde det även funka åt andra hållet.
Modellen i sig blir vare sig bättre eller sämre, men med det argumentet så borde extraminuset på t.ex Interrogator-Chaplain, Chaplain och Librarian för att det finns en Land Raider med i armén tas bort eftersom det i sig inte gör modellen ett endaste dugg bättre.
Sedan att det känns som att det inte skulle att skada att uppmuntra till att bygga rena listor (DW finns men det är flera år sedan jag såg en RW-lista) då det gynnar mångfalden.
Fluff är tufft!!
GLinus
Re: Dark Angels
Inlägg av GLinus »
jeppeapan skrev:Varför ska lr multi-meltan ge -2?:)
Jag tycker att den är så pass bra för vad den kostar. Jag skulle föreslå att den ger det för alla Marines, men att man då också har de plusen som mallen och jag har med för olika varianter. Då går det lite mer på ett ut. En Crusader ger då samma avdrag som en vanlig Raider om Crusadern har en MM och den vanliga inte har det. Det känns i mina ögon helt fair då de på det hela taget blir lika bra då, om än på olika saker.
Fluff är tufft!!
Asplund
Re: Dark Angels
Inlägg av Asplund »
Vad än för morfininspireration Linus kan ha fått så ger jag mitt godkännande :)
GLinus
Re: Dark Angels
Inlägg av GLinus »
Jag kan, eventuellt, ha tagit i för mycket med att DA ska börja på 115 poäng när jag har lättat upp en del minus i övrigt, men jag tror inte att de ska börja på mindre än 110 poäng.
Ska räkna på lite listor innan jag kommer med fler kommentarer på det.
Fluff är tufft!!
