1. Calculate a composition score according to "RT-kompmallen" for each of your four army lists.
2. If any list scores below 20, redo it, it can't enter the tournament.
3. Add the four scores together (keep fractions) to arrive at a number between 80 and 400. Divide that number by 10.
4. That number (8-40, round fractions normally) is the team's final composition score. Formula: Team comp score = (army 1 comp + army 2 comp + army 3 comp + army 4 comp)/10.
5. Captains should include individual composition scores and the team score when they finalize their lists by sending them to bsklag2009@yahoo.se no later than October 23.
6. Comp scores directly affect game results as follows: Compute the result by adding up the four individual games (0-20) to arrive at the result in tournament points (0-80). Then calculate the difference (if any) in composition scores for the teams. The team with the higher composition score add that difference to their tournament points, and the team with the lower score subtract the difference from their points (a score can be modified above 80 or below 0). This is the final score.
Example: Team A win against Team B 60-20. Team A have a composition score of 15 and team B have a comp score of 23. The difference in comp is 23-15 = 8, therefore 8 points will be subtracted from Team A’s tournament points and 8 points will be added to team B’s tournament points, making the final score 52-28.
7. Tournament standings are calculated on final game results. The team with the highest total after five games will win the tournament. In this case comp scores will be the tie-breaker, with the advantage going to the team with the higher score.
How composition will affect the tournament
"Never tell me the odds."
Re: How composition will affect the tournament
This is the way composition will affect team matchups:
The first round will be drawn by composition score only so that teams with similar scores will face each other.
The following rounds will be decided by tournament points, with composition deciding ties, so that the team with the most points will face the team with the second most and so on going down the list until all matchups are created. In the case of ties the team with the lower composition will be selected first. (If two teams have already met the next team on the list will be paired against the team with the higher number of points.)
This link leads to the 5.4 version of the composition list, this is the final version before the tournament.
http://www.svenska40k.se/forum/viewtopic.php?f=52&t=719
Edited a minor clarification, final scores cannot be above 80 or below 0.
After a vivid discussion among the organizers I have now yielded to the majority and final scores can be modified above 80 or below 0.
