Mission Vinterslaget 2013
Vinterslaget, Halmicon, Hammarslaget
Moderator: tue
tue
Inlägg av tue »
Tack till Pär Hylander som komponerat missionen.
Glöm inte att skicka in era armelistor seanst den 16 februari samma datum gäller för förbetalning.
Each game can give up to 20 points, depending on the difference in Victory Points in each game:
1 VP more than your opponent 11-9
2 VP more than your opponent 12-8
3 VP more than your opponent 13-7
9 VP more than your opponent 19-1
10 VP more than your opponent 20-0
Place objective markers: No objective can be placed within 6” of any battlefield edge or within 12” of another objective. No objective can be placed in, or on, impassable terrain, buildings or fortifications.
Controlling objectives: You control an objective if there is at least one model from one of your scoring units, and no models from enemy denial units within 3” of the centre of the objective.
Scoring / Denial units: See page 123 in the rulebook.
Slay the Warlord: If, at the end of the game, the enemy’s Warlord has been slain, you score 1 Victory Point, unless otherwise stated in the mission.
First Blood: The first unit, of any kind, to be removed as a casualty during the game is worth 1 Victory Point to the opposing player at the end of the game, unless otherwise stated in the mission
Linebreaker: If, at the end of the game, you have at least one model from one or more scoring or denial units in the enemy’s Deployment Zone, you score 1 Victory Point, unless otherwise stated in the mission. Units that are falling back or have gone to ground do not count.
All missions got the Night Fighting and Reserves rules
Follow the following steps in every game:
1. Roll-of to determine who chooses deployment zone.
2. Place objectives, the player that chose their table half starts to place objectives. (Not in mission 2 due to killpoints)
3. Roll for Warlord Traits
4. Roll for Night Fight
5. Roll-off to see which player chooses whether to deploy first or second.
6. The player that deployed his army first goes first unless his opponent can Seize the Initiative
Match 1
Dawn of War
Primary: 4 Objectives 2p each. Place the first objective in opponents deployment zone. The second objective in his table half.
In the begining of GAME turn 3: Scatter a fifth objective from the centre of the table 3d6" (reroll hits until scatter). This objective is also worth 2p.
Secondary: First Blood, Linebreaker, Slay the Warlord
Match 2
Vanguard
Primary: Killpoints
Secondary: First Blood, Linebreaker (1p for each unit, fullfilling the linebreaker rules, in opponent deployment zone), Slay the Warlord
Match 3
Hammer and Anvil
Primary: 3 Objectives. One in the centre of the table worth 5p. Each player places one each in his opponents deployment zone worth 3p each.
Secondary: First Blood(worth 2p), Linebreaker, Slay the Warlord
Match 4
Vanguard
Primary: 6 Objectives worth 2p each. Place 3 objectives each and they must be placed on the opponents side.
Heavy choices are scoring and if they are controlling an objective you only recieve 1p.
Secondary: First Blood, Linebreaker, Slay the Warlord, Destroying a Heavy choice is worth 1p.
Match5
Dawn of War
Primary: 4 Objectives worth 2p each. Place the first objective in opponents deployment zone. The second objective in his table half.
In the beginning of every GAME TURN scatter the objectives 1d6", a hit means it doesnt scatter.
Fast choices are scoring and if they are controlling an objective you only recieve 1p.
Secondary: First Blood, Linebreaker, Slay the Warlord(worth 2p), Destroying a Fast choice is worth 1p.
Hylander
Re: Mission Vinterslaget 2013
Inlägg av Hylander »
Konstigheter eller oklara saker kan ni fråga om här direkt så jag kan fixa eller förklara.
PIMPWARRIOR99
Inlägg av PIMPWARRIOR99 »
Sista missionet:
Vad händer om objektiv åker av brädet?
/Elias
Trivia: Do you like Power Klaws? Within the limitations of the Force Organization slot you can have 292 Power Klaw attacks on the charge. All ignoring armour saves; all at S7, S9, or S10. All for only 3965 points. Now THIS is powergaming.
Hylander
Det skall de inte kunna. I så fall stannar de bara innan de åker av.
Valrosskorv
Inlägg av Valrosskorv »
Hur fungerar Fortifications?
Hylander
Jag förutsätter att Tue kör det, som börjar bli lite standard, att man inte får flytta terräng och att man inte får sätta i inpassable. OM man inte kan ställa det i sin deployment pga impassable så får man inte ställa ut det.
tue
Inlägg av tue »
Ja det stämmer standard kan du ställa ut det kan du ställa ut det annars är det dött.
inte i impasable och får inte flytta terräng
Dante82
Inlägg av Dante82 »
Hur exakt fungerar Primary: Killpoints? Är det 1KP = 1VP?
I uppdrag fyra och fem, är det ett VP för varje heavy/fast attack eller är det max 1 gång per spelare?
Hylander
1KP = 1VP Yupp.
Varje fast och heavy ger 1 VP vid mission 4 resp 5.
Skall förtydlinga i texten.
