Lite frågor till SWEFAQ gruppen
- refabricated
Re: Lite frågor till SWEFAQ gruppen
Men vi har ju fått svar?
Karios / Corbulo == no!
Annat == yea!
Annat == yea!
Ledsen för sent svar. Skall se om vi kan reda ut allt som uppkom under TT snarast och släppa en ny version. Dessa bör dock vara spikade:
Corbulo and re-rolls from Reserves
Corbulo can't use the re-roll from the Far-Seeing Eye while he is in Reserves.
Kairos Fateweaver and re-rolls from Reserves
Kairos can't use the re-roll from the Staff of Tomorrow while he is in Reserves.
Thrust/Eldar Jetbike moves in non-Jet Pack/Jetbike units
Thrust moves and Eldar Jetbike assault-moves can still be made by models with these special rules, even if they are part of a unit with models without them.
Run moves and models that cannot run
A unit cannot choose to run if it contains a model that cannot run (a model on Bike, Slow and Purposeful, carrying the Relic, etc).
Upgrades for upgraded models
A model may only purchase an upgrade if it is legal for that model to have that certain upgrade in the armylist. For example: If an upgrade can be given to "any XX" and "any XX can be upgraded to YY", then YY cannot purchase the upgrade. If the upgrade could have been given to "any model", then YY could have purchased that upgrade.
Drones and First Blood
A unit of Drones does not give up a Victory Point for First Blood. The army will still give up a Victory Point for First Blood if another unit later is killed.
Charge moves with Cavalry/Bike bases
When charging with a unit with non-circular bases the first model to move must move in such a way that no part of its base has moved further that any other part of its base. I.e. it must move without changing its facing. All other models may move in any fashion as long as no part of their bases moved further than the rolled charge distance.
Edit: Rulingen om att inte kunna användas av planen försvinner alltså i och med Kairos- och Corbulo-rulingarna.
Kanon att detta kommer på pränt
Detta känns lite inkonsekvent. Även om jag förstår varför så sticker det lite i ena ögat. Jag är dock nöjd så länge en tolkning finns i dokumentet, ville mest peka ut det.Katarsis skrev:Thrust/Eldar Jetbike moves in non-Jet Pack/Jetbike units
Kanske fel ställe, men sammanhanget känns rätt: får man turbo-boosta i en enhet där alla inte har turbo-boost?
Riktigt bra jobb hur som!
Mathias Lamu
Uppsala - VSSU
Uppsala - VSSU
Ja, Turboboost görs på modellbasis.kelaino skrev:Kanske fel ställe, men sammanhanget känns rätt: får man turbo-boosta i en enhet där alla inte har turbo-boost?
Är det inte bara fiskarnas fordonsdroneunits som är undantagna från victory points? Eller de kanske inte kan ta renodlade dronesqauds som fast attack längre? Hursomhaver borde rulingen gälla spore mines i alla dess former, åtminstone i en månad till. Och grey knights servo skulls har väl liknande regler?
Servoskulls är inte en enhet
Det stämmer att det bara ska vara drones som har hoppat lös från fordon.
Run moves gör också på modellbasis, däremot räknas hela enheten som den har sprungit NÄR DET GÄLLER SKYTTE. Klart som fasen en enhet kan springa så länge relicbäraren står still.Katarsis skrev:Ja, Turboboost görs på modellbasis.kelaino skrev:Kanske fel ställe, men sammanhanget känns rätt: får man turbo-boosta i en enhet där alla inte har turbo-boost?
Nej, det gör det inte. Run är på enhetesbasis. Alla räknas som om dom har "runnat", kan då en modell inte göra det så får enheten helt enkelt inte göra manövern.Flogger skrev:Run moves gör också på modellbasis, däremot räknas hela enheten som den har sprungit NÄR DET GÄLLER SKYTTE. Klart som fasen en enhet kan springa så länge relicbäraren står still.Katarsis skrev:Ja, Turboboost görs på modellbasis.kelaino skrev:Kanske fel ställe, men sammanhanget känns rätt: får man turbo-boosta i en enhet där alla inte har turbo-boost?
