Orks rykten
Orks rykten
Läste detta i morse, tyckte det låter asnice :)
Here's a little bit I was informed of by a friend. He's up in Scotland and good mates with a GW employee and apparently he's had a look at the next Ork codex.
In essence, Orks are the next 40k race getting an update.
Choppas are going to give +1 strength amended, see 19/3/14
Waaagh! is now old Fleet. So move, run and assault in the same turn.
Power Klaws are double strength, AP1
That's what I've heard so far. I can't verify the information since it's word of mouth but so far, his contact has been rather accurate on the more recent releases to date.
Orks
Still have the Mob and Furious Charge rules
Orks now have 6+ FNP
Each unit now has Waaagh! points
Waaagh! charge now per unit, not per army.
Sluggas generate 1 Waaagh! point for each turn in combat
Shootas generate 1 point for each unit kill with shooting
Waaagh points also generated from every 3 units of 10+ models (unsure of this one)
Mega Armour now has Deepstrike rule
Boyz
Unit gets 2pts cheaper and weapons are now upgrades.
Choppas are AP6. +1str AP4 on charge. Cost 1pt each
Shootas cost 2pts each
Big Choppas now +2str AP4. AP3 on charge
Lootas
Deffguns are now options
Unit is now cheaper and has more options for weapons
Gains new rule: Loot
- If in base-to-base contact with a destroyed vehicle, they can fire one of its weapons. Not clarified if per turn or per game.
Flash Gitz
Weapons now have random range instead of random AP
New range is 12 + 3D6”. Triple 1 on range causes Overheat
Weapon upgrade options include +1Bs, +1 Attack, Blast, Skyfire
Stormboyz
Can now assault Fliers
Must move 18” on movement if charging a flier
Grots
Whole bunch of Grot units, including Grot Buggies, Whirlybirds, Rokkits and Snotlings
Grot Boss unit – has same stats as an Ork Boy with +1Bs
Gretchin
Now separate from Grots
Units of up to 20, 2pts per model
Has an upgrade called Control Collars: basically, bomb collars that explode when the unit fails Leadership. Think alternative for Runtherders
Weirdboyz
Now have a warp powers table; either Divination, Gork or Mork
Use Waaagh! points for powers
Waaagh points also contribute to Weirdboy’s death. When he dies, casts "Eadbanga" on himself. More points means bigger and more powerful explosions
Bomb squigs now can be taken as units
Includes more options. Can have upgrades for more powerful explosions or melta
Due to Waaagh! changes, Ghaz has 3 Waaaghs! Not sure if armywide or distributed to units
Killa Kanz to Elites – may require Grot boss
NEW UNITS
New unit of Warlord Nobz, can be taken as HQ. One Nob is the Warlord. On death, another Nob is the Warlord. Must kill entire unit for the kill
Possible mek tanks with upgrades
- Upgrades including a KFF and a SAG that shoots bomb squigs – if they miss you place a bomb squig
SAG and Flakk guns might be taken as Big Gunz unit
Halftrakk unit called Gutripper
Multi-wound Squiggoth-like beast
Supplements
Goffs and Blood Axes first
Blood Axes can allow Kommandos as troops and can ally with Guardsmen
NEW BOXES
Snapfit mekboy and weirdboy?
Deffkopta kit
Cybork body parts box
Combi Flash Gitz/Tankbustas box
Är det bara jag som saknat det här med att charga flyers? :D
Jonke
Re: Orks rykten
Inlägg av Jonke »
Tycker det låter för bra för att vara sant... :o
Re: Orks rykten
Har inte dessa blivit debunkade ett flertal gånger redan? Allt jag har läst om dem är att de är falska...
Anton
Re: Orks rykten
Inlägg av Anton »
Alla verkar tro att de är falska i alla fall. Har inte sett någon som "vet".
Skulle säga att de antingen är helt falska, eller så är det en person som har tittat i boken och berättat vad han kom ihåg för sin polare som i sin tur tolkade vad han hörde och skrev ner. Vilket skulle innebära att de har ett korn av sanning i sig.
"New Boxes" matchar väldigt dåligt vad vi har hört tidigare. Och matchar inte armélistan så bra heller.
Re: Orks rykten
Darnok på warseer "vet" att de är falska.
