Säljes: Valhallan gubbs i metall.
Snot
Inlägg av Snot »
Latar mig och orkar inte översätta från min långa Ebay post.
Here is a complete list of all parts/models that you are bidding on. I will list them under two sections, complete and incomplete.
General information of quality:
Many of these models are missing the small metal line between their feet, as shown in the picture, and a few will have a 1.1mm hole in their heel for pinning purposes.
For detailed descriptions on a particular model feel free to contact me and I will try to get back to you as soon as I can.
The complete models/sets are as follows, listed in no particular order and described only by equipment.
Complete
37x Guardsman with Lasgun (One is painted, others have some paint left from cleaning)
1x Guardsman with Comms and Lasgun.
4x Lascannon Heavy Weapon Crew, with 2x Lascannons, containing Weapon, mounting, shield and 2 wheels each.
2x Heavy Bolter Heavy Weapon Crew, with 1x Heavy bolter, containing Weapon, mounting, shield and 2 wheels.
8x Mortar Heavy Weapon Crew, with 4x Mortars, containing Mortar and mounting each. (one mortar black, one other showing parts of black still)
2x Rocket Launcher Heavy Weapon Crew with one crewmember holding the Rocket Launcher.
2x Autocannon Heavy Weapon Crew with 1x Autocannon, containing Weapon, mounting, shield and 2 wheels.
2x Sitting Guardsmen with lasgun, originally intended to sit on a tank to my knowledge.
5x Sergeant with Chainsword+bolt pistol (one has some paint left and one other has had his bolt pistol removed with a file)
2x Guardsmen with Grenade Launcher
2x Guardsmen with Flamer (one has paint left)
1x Converted Guardsman with flamer (old flamer model with half the flamer exchanged with a new plastic flamer)
3x Guardsmen with Meltagun
1x Commander Chenkov (conversion begun on right arm, its direction has changed and is pinned, no permanent harm is done should one wish to revert the ongoing change)
1x Lieutenant with chainsword (entire hand and pistol is gone, filing not completed, not really usable in current state)
Incomplete
1x Heavy Bolter Heavy Weapon Crew with 1x Heavy Bolter containing Weapon, mounting, shield but no wheels
1x Heavy Bolter/Autocannon shield (shield ONLY)
2x Mortar Heavy Weapon Crew, with 1x Mortar, containing only the Mortar, no mounting.
1x Mortar Heavy Weapon Crew, just one holding a lasgun, can easily be used as a regular guardsman.
I estimate that the models weigh somewhere near 115 ounces, using 1 standard white metal model = 1.5 ounces as reference. Given that many of these are older and used more lead, and that the Heavy Weapons are somewhat larger than your average model. 115 ounces is ~3.26 Kilograms.
I will ship them in a small cardboard box filled with softening materials to make sure they don't move around too much or scrape eachother alot.
Therefor I will list the total weight to 3.5kg or 123.4 Ounces as a reference to calculate shipping.
Priset är 2000kr, + frakt, som är 175kr.
Fler bilder skickas på begäran.
(1.2 MiB) Nerladdad 192 gånger
Saeculum Obscurums Forum
