So, hypothetically
So, hypothetically
As you've probably seen we're now 37 teams. Needless to say an odd number is less than perfect in these circumstances; however, we've made a promise that everybody will get to play and so we don't want to cut anybody off.
Now, we may use an ingenious system where three teams face each other on six tables. This is not what you signed up for, but is this something you would be prepared to accept?
Remember this is only a hypothetical, hopefully we'll be a nice even number of teams, and if not, we may not use this method. I'm only curious as to whether this is a plausible option or not.
"Never tell me the odds."
Re: So, hypothetically
I think it is ok. It's not as good as the normal setup, but i realy think it sucks to not play for an entire heat.
Is it not possible to have a "borrowed" team? I could bring an extra army that some extra people could use in an emergency team. I think that some of the foreign people had some extra guys and they might be able to alternate and play a couple of games while rest of their team is playing?
It could be fun for the extra folks to take on an opponent with an army they have never played before. The people in the extra team could also vary.
I can bring a Standard 1A Tau army with 100% WYSIWYG.
In the ETC the odd team problem have been solved by introducing a mercenary teem with players from different countries..
I think a mercenary team is the best idea as yet, and I've urged the remains of splintered teams to come to the convention anyway. Let's say two guys come in this way and we persuade two people (should be easy to do) from the teams with extra players, problem solved. If we just get a few more extra armies, we're all set.
Jag kan ta med 1500 Daemons för utlåning.
Tycker mercenary-team låter som en bättre lösning än 3 lag i en match, men funkar det inte att få ihop en mercenary-team från spelare utan lag och spelare från lag med fler än 4 medlemmar tycker jag det är bättre att spela nån sorts 3-lags-match än att ett lag får stå över.
Fundera ut något bra sätt att matcha listor och hur kompen påverkat för 3-lags-matcher ifall det skulle behöva komma till det.
the godfather
trelagsmatchning är ju lätt. det är poängberäkning som är svårt. som tur är blir det ju de lag som ligger i botten som drabbas. illa dock i första matchen då det inte är bottenlag (om det inte är seedning a la sydcon)
a1
a2
a3
a4
b1
b2
b3
b4
c1
c2
c3
c4
a1 vs b4
b1 vs c4
c1 vs a4
b2 vs a3
a2 vs c3
c2 vs b3
matchning som normalt där a väljer en arme, b sätter ut hans motståndare, b sätter ut arme, c väljer en motståndare.
eller hur lagen möts inbördes
ab
ba
bc
cb
ca
ac
det kluriga är som sagt hur man delar komp, och poäng på tre lag, det enkla är ju att låta lagen spela om udda siffror, vilket inte blir fallet när två lag möts.
a1
a2
a3
a4
b1
b2
b3
b4
c1
c2
c3
c4
a1 vs b4
b1 vs c4
c1 vs a4
b2 vs a3
a2 vs c3
c2 vs b3
ab
ba
bc
cb
ca
ac
Det finns väl iofs inget som säger att det måste vara lagen i "botten" som får en trekant.
