General Information about Codex: Space Wolves
Sagas are out, replaced with Warlord Traits
6 new Space Wolves Tactical Objectives
New Space Wolves Psychic Discipline: Tempestas (Source didn't get any actual rules though)
'Space Wolves Unleashed' Detachment FOC:
Identical to standard FOC, except may take up to 6 HQs
May re-roll Warlord Traits
Each unit joined by an Independent Character rolls a d6, on a 6+ that unit gains Outflank. Troops choices get +2 on this roll.
Great Company Formation:
1 Wolf Lord
1 Wolf Guard Battle Leader
1 unit of Wolf Guard
5 units of Grey Hunters
1 unit of Wolf Scouts
5 units chosen from [Blood Claws, Swiftclaws, or Skyclaws]
2 units of Long Fangs
Grants two special rules, source did not get them
Space Wolves Relics (Source didn't get rules, just name and type of item)
Armor of Russ (Armor)
Bite of Fenris (Bolter with two fire modes)
Black Death (Frost Axe, Rule: Whirldwind of Death)
Helm of Durfast (Wargear)
Fangsword of the Ice Wolf (Frost Sword)
Wulfenstone (Wargear)
Logan Grimnar - Lord of War
Epic new model, comes with a sort of grav-chariot called 'Stormrider' pulled by two enormous Fenrisian wolves, but he can be used without it as well.
Stormrider
Treated as a vehicle, didn't get AVs, has a 4+ Invulnerable save and cannot suffer Penetrating hits (all Pens are reduced to Glances).
Gives Logan 4 S5 Ap- attacks on a turn when he charges.
Logan loses Deep Strike if he takes Stormrider
Lots of other cool rules, but didn't get those.
Njal Stormcaller
No new model shown in codex
Looked to be mostly the same, no specific information
Ragnar Blackmane
Also looked to be mostly the same, no specific information
Ulrik the Slayer
Canis Wolfborn
Again, looked to be mostly the same, no specific information
Harald Deathwolf
The resin Thunderwolf Cavalry character model assigned a name
Didn't get the rules/stats.
Bjorn the Fell-Handed
Epic new plastic model, part of a box that makes a regular SW Venerable Dreadnought, Bjorn, or a new special character Dreadnought named 'Murderfang'.
No longer becomes a VP objective when he dies.
Wolf Lord
Mostly the same, no specific information.
Rune Priest
Mostly the same.
Specifically noted as starting at Mastery Level 2.
No other information.
Wolf Priest
Blood Claws Pack
Wolf Guard Leader upgrade available
May take a Stormwolf as a Dedicated Transport
Lukas the Trickster
No specific information, probably the same.
Grey Hunters Pack
Any model may add a Close Combat Weapon for +2 points
One Special weapon per full five models still, but costs raised to same as C:SMs
Wolf Guard Upgrade available
Dreadnought
Not sure, but might have an option for a Helfrost Cannon
Otherwise similar to old codex, no other information
Murderfang
Crazy-awesome special character Venerable Dreadnought
Wolverine + Dreadnought + Extra Insanity = Murderfang
Wargear:
Searchlight
'Murderclaws' with underslung Storm Bolter and Heavy Flamer
Special Rules:
Furious Charge
It Will Not Die
Rage
Rampage
Murderlust
Options:
May take a Drop Pod
'Murderclaws' - A pair of enormous, even for a Dreadnought, Lightning Claws made of 'alien ice that never melts or loses sharpness'
S7 AP2 - Melee, Master-Crafted, Shred, Specialist Weapon
Definitely has an option for a Helfrost Cannon
Can also have an enormous Power Axe and Storm Shield, said to look incredible.
Some special rules, but didn't get them
Iron Priest
Options appeared to be nearly identical to old codex,
Can take a unit of 1-5 Servitors, rules also looked the same as old codex
TEAM JACOB!!!
- bolterochkniv
TEAM JACOB!!!
Elias Österlund
- bolterochkniv
Re: TEAM JACOB!!!
Lone Wolf
Rules nearly identical to old codex, didn't get points cost
Owning player no longer gains a VP if they die
Wolf Guard Pack
This unit is just for Wolf Guard in Power Armor.
Have a similarly wide array of options as in the old codex, couldn't get specifics though
Wolf Guard Terminator Pack
What it says on the tin, Wolf Guard in TDA
with Storm Bolter and Power Weapon base
Options (any model in the unit can take these, this isn't all of the options though):
Thunder Hammer & Storm Shield
Pair of Wolf Claws
Power Fist
Frost Axes
Frost Sword
Combi-weapon
Heavy Flamer
Assault Cannon
Cyclone Missile Launcher
Arjac Rockfist
Wolf Scouts
Source totally forgot to look at them. Sorry guys.
Swiftclaw Pack
Skyclaw Assault Pack
Thunderwolf Cavalry
As noted previously:
Stormwolf - Fast Attack
BS4 - F12 S12 R12 HP3 - Vehicle (Flyer, Hover, Transport)
Wargear:
Twin-linked helfrost cannon
Twin-linked lascannon
Two twin-linked heavy bolters - May be replaced with a Skyhammer launcher for free, or two twin-linked multi-meltas
Ceramite Plating
Special Rules:
Assault Vehicle
Power of the Machine Spirit
Transport:
Transport Capacity - sixteen models
Fire Points - none
Access Points - One ramp at the front of the hull
Stormfang Gunship - Heavy Support
BS4 - F12 S12 R12 HP3 - Vehicle (Flyer, Hover Transport)
Wargear:
Helfrost destructor
Two Stormstrike missiles - May be replaced with a twin-linked lascannon
Ceramite Plating
Special Rules:
Transport:
Transport Capacity - six models
Fire Points - none
Access Points - One at rear of the hull
Helfrost cannon
dispersed - R24" S6 AP3 Heavy 1, Helfrost, Blast
focussed - R24" S8 AP1 Heavy 1, Helfrost
Helfrost destructor
dispersed - R24" S6 AP3 Heavy 1, Helfrost, Large Blast
focussed - R24" S8 AP1 Heavy 1, Helfrost, Lance
Helfrost - If a model suffers one or more unsaved wounds from this weapon, it must pass a separate Strength test for each wound suffered or be removed from play
Land Speeder Squadron
Same as Codex: Space Marines
Fenrisian Wolf Pack
Nearly identical to old codex, no specific information
Long Fangs Pack
Couple of new options for squad leader, who is now called a 'Long Fang Ancient'
Source did not get if they had an option for Flakk Missiles
Might be able to take a Stormwolf/Stormfang as a Dedicated Transport, not sure about this though
Otherwise nearly identical to old codex, no other information
Predator
Whirlwind
Vindicator
Land Raider and variants
Rhino and Razorback
No Helfrost Cannon option for the Razorback, same as Codex: Space Marines
Drop Pod
Notable Exclusions from Codex: Space Marines
No Stormtalon
No Storm Raven
No Hunter or Stalker
Space Wolves AA options: Stormwolf, Stormfang, ADL gun emplacement, and Allies
Elias Österlund
Re: TEAM JACOB!!!
Mycket najs där verkar det ju som. Flygarna verkar ju ganska badonkers men utan poängkostand så vet man ju aldrig.
Dreadnought med Power Axe och Stormshield låter ju helt awesome!
Re: TEAM JACOB!!!
Logan Grimnar blir väldigt mycket Åskguden Tor om han ska åka svävande vagn på det sättet.
Hoppas på en snygg modell om det stämmer - Go Space Vikings!
- bolterochkniv
Re: TEAM JACOB!!!
dagens ris går till personen som döpte den andra dreadkaraktären till "Murderclaws"
Elias Österlund
Re: TEAM JACOB!!!
Vilket är ganska märkligt, för är inte Arjac Rockfist "Tor"? Har alltid tänkt på Logan som mer lik Oden.Kaptenen skrev:Logan Grimnar blir väldigt mycket Åskguden Tor om han ska åka svävande vagn på det sättet.
Re: TEAM JACOB!!!
Undrar hur kärran funkar mot grav? Blir den fortfarande immobilised iom att de aldrig pennar som vanliga vapen?
Re: TEAM JACOB!!!
Hela Space Wolves flirtande med Asasagan är en enda stor face rape (och då menar jag inte en kapning av socialamedierkonton) på Nordisk mytologi. De är snarare söner till Loki hela bunten. -Tvi!Rasmus skrev:Vilket är ganska märkligt, för är inte Arjac Rockfist "Tor"? Har alltid tänkt på Logan som mer lik Oden.Kaptenen skrev:Logan Grimnar blir väldigt mycket Åskguden Tor om han ska åka svävande vagn på det sättet.
Med det sagt så kan det ju ändå vara rätt fräcka modeller.
Re: TEAM JACOB!!!
Jo de plockar lite varstans och lägger in på olika gubbar.
Njal har en korp och skägg á la klassiska Oden-porträtt, men det är korpen som är enögd..
Finns det någon som har en skön sammanställning på vilka som är vad?
Ultramarines = Romare
Space Wolves = Vikingar
White Scars = Mongoler
osv..
osv..
Re: TEAM JACOB!!!
Trodde UM var antika greker...
