40k-kompmallen 6th Beta
Gud er Dansk
Re: 40k-kompmallen 6th Beta
Ok thanx! To the author of the system, is it ok for me to use it for my tournament in Denmark?
Absolutely! And we would appreciate it if you afterwards told us how you used the comp points (how they affected the tournament) and what you thought about that particular system (pros/cons).
Gud er Dansk
Super! Ok then, Ill make some inclusions for the new Tau, Eldar, and the supplements and test them in our tournament (unless you come up with some rules for these factions, then Ill use those you make) and get back to you!
Cheers, Patrick
Cheers, Patrick
Gud er Dansk
Could you give me an example of how Kompmallen works? Im trying to piece the Tau together so I came up with this:
Tau Kompmallen
Commander
Missile Pods/TL MP + 10 each
PEC + 20
Iridium Armour +10
Shadowsun +20
Farsight with a Bodyguard numbering more than 3 Crisis Suits at the start of the battle + 20
AunShi – 30
AunVa – 15
Stealth Suits – 5 per suit
Riptide +10, +15 for the second, +20 for the third
Riptide with Heavy Burst cannon -5
Riptide with TL Plasma Rifles – 5
Crisis Suits: +5 for every 3 Missile Pods in the army (except commander)
Fire Warriors with Carbines – 10 per unit
Kroot Shaper – 10 per shaper
Devilfish – 20 per devilfish
Pathfinders – 5 for each model with an Ion Rifle or Rail Rifle
Pathfinders – 5 if Grav, Recon or PA drones are included in the unit
Vespid – 15 per unit
Sun shark bomber -15
Razorshark fighter – 10
Broadsides with HYM +10 per Broadside
Broadside with HRR – 10 per Broadside
Broadsides + 5 for every Missile Drone in the unit after the 2nd
Tau Kompmallen
Commander
PEC + 20
Iridium Armour +10
Shadowsun +20
AunShi – 30
AunVa – 15
Gud er Dansk
I also thought about allies and fortifications:
Allies & Fortifications
All Allied choices cost what they do in their own entry in Kompmallen + the following:
If battlebrothers, +20 per choice
If allies of convienience, +10 per choice
If desperate allies, +5 per choice
Aegis defence line +20
Skyshield landing pad +10
Bastion + 10
Fortress of redemption + 50
Bastion + 10
ChaoticBob
Är den här tråden och kompmallen fortfarande aktuell? Den står fortfarande som beta efter ett år, betyder det att den fortfarande inte är färdig eller att den har övergivits helt?
Hittar ingen annan kompmall för 6:e upplagan, nämligen.
För tillfället finns Flabbergasmallen och Lbk mallen. Denna mall arbetas inte på längre.
