Rules questions
Hylander
Re: Rules questions
Inlägg av Hylander »
The Questions skrev: Questions
Grav weapons
1: 'If I shoot a Grav-Weapon at a mixed armour unit, what do I need to wound?'
2: 'If I shoot a Grav-Weapon at a vehicle that is Immobilised already, do I inflict two Hull Points damage as per the Immobilised result in the vehicle damage chart?"
3: "If I resolve a Grav-Weapon hit on an Obscured vehicle and roll a 6 thus causing an Immobilised result and removing a Hull Point, do I get to roll a cover save when no Glancing or Penetrating hit has been made?"
Blast weapons/gets hot with rerolls
1: Is it correct to assume that if a model has rerolls to hit (from whatever the source, be it twin linked, BS6 or reroll 1s etc), it gets to reroll both the roll of a 1 for gets hot that you have to do when firing a blast weapon like a plasma cannon, and the scatter dice? See the BRB page 33 and 37.
Jet pack and Jump units assault moves
1: In the main rulebook it says under the Skyborne rule for Jump units "When using a Jump pack (whether moving, charging or falling back...) a model can move over all other models and all terrain freely. However if the model begins or ends its move in difficult terrain, it must take a dangerous terrain test...". So does this mean a Jump pack equipped unit that uses its Jump pack to charge ignores difficult terrain checks when charging and instead just takes a dangerous terrain test?
2: Do Jet pack units also ignore difficult terrain when charging and take dangerous like Jump packs since they have the same Skyborne rule?
Cheers, Patrick
The Answer skrev:Let's see if i can help you :)
1; covered in swe-faq.
2; as far as i know, 1 roll of six removes a hull point and immobilizes you, the second 6 will remove a hull point and since you are already immobilized remove another hull point. Thus, 2 6:s will remove 3 hull points.
3; covered in swe-faq
Blast and so on:
1; to the best of my knowledge you reroll both.
Jump:
1 & 2; On the last pages of the rules book there are tables stating how each unit type charges. Just follow those, there are no "swedish house rules" about jump/jet- units charging.
Sådär kanske
SamuelB
Re: Rules questions
Inlägg av SamuelB »
How about mixed units and Assultmove.
Since they missed it in the SWE-Faq. How will you rule it?
Here is the thread under rules:
http://www.svenska40k.se/forum/viewtopic.php?f=4&t=9991
Hylander
Re: Rules questions
SamuelB skrev:How about mixed units and Assultmove.
Allt sker på modellbasis sånär på "run" som görs på enhetsbasis.
Re: Rules questions
Så det är fritt fram för drones att hoppa runt in en enhet broadsides? Kan man göra run ifall man har en bike-character med i enheten? Får denne i så fall boosta?
Hylander
Re: Rules questions
Ja.
Ja, enheten får göra en run men då bara med icke bike modeller.
Nej, eftersom enheten har gjort en run.
gertinc
Re: Rules questions
Inlägg av gertinc »
Hi, I got a rules question:
How does the grey knight psychic power Dark Excommunication interact with the Chaos Daemons Grimoire of true names? Since DE removes all daemonic gifts (excepts steeds), the book is removed (for the phase), but what about its effect?
best regards
Jens
Re: Rules questions
In my opinion you can prevent the book from being used in the following turn if you are base to base with the wielder of the book. Although you can not shut down the effect immidiately.
(If the effect of DE is still there outside the assault phase, have to check codex)
This is my personal view, not a tournament ruling.
Re: Rules questions
DE is only until the end of the phase. So it shouldn't effect the grimoare at all.
bjorn
Re: Rules questions
Inlägg av bjorn »
Gamla brodsides får stå på 40baser?
//Björn
SamuelB
Re: Rules questions
Inlägg av SamuelB »
När man väljer Psy-krafter i dom gamla codexarna innan matchen får man välja att gå på Rulebook eller Codex? eller har man det som står på armelistan alltid?
